The Main Features of GPBC and GPBD
Postby hone » Mon Dec 12, 2016 7:19 pm
GPBC
GPBC provides 4 GPON ports.
GPBC uses the SFP optical module of only Class B+.
The maximum power consumption of GPBC is 78 W, and the average power consumption of a single port is 19.5 W.
A single PON port on GPBC supports the maximum split ratio of 1:64.
Compatible with all features supported by the H801GPBC board
New features:
GPBD provides 8 GPON ports.
GPBD uses the SFP optical modules of Class B+ and Class C+.
The maximum power consumption of GPBD is 49 W, and the average power consumption of a single port is 6.125 W.
A single PON port on GPBD supports the maximum split ratio of 1:128.
GPBD supports received signal strength indicator (RSSI) detection and optical signal transmission control of the optical module.
