Can AC and DC Power Modules Be Used in the Same Switch?
Postby hone » Wed Dec 07, 2016 7:14 pm
Fixed Switches
Product Series
S3700/S5700/S6700
Model
S3700-26C-HI
Supported
S5710-28C-EI
Supported
S5710-52C-EI
Supported
S5700-28C-HI
Supported
S5700-28C-HI-24S
Supported
S5700-EI (non-PoE)
Supported in V200R005
S5700-SI (non-PoE)
S6700
S5710-HI
AC and DC power modules cannot be used together, but 350 W and 1150 W AC power modules can be used in one switch.
S5720-HI
Modular Switches
When a switch does not use a PoE power module:
AC and DC power modules cannot be used together in the same type of power slots. Power modules with different power values cannot be used together either.
Cisco 2821
