Can the Switch Check for DHCP Packets with Duplicate Options
Postby jorna » Thu Sep 22, 2016 7:50 pm
Can the Switch(like S5700)Check for DHCP Packets with Duplicate Options?
In V100R006 and later versions, you can run the dhcp anti-attack check duplicate option command in the system view to enable the switch to check for DHCP packets with duplicate options.
Cisco Catalyst 2924
