How to Determine that Configured OSPF Router IDs Conflict?
Postby hone » Sun Aug 21, 2016 10:49 pm
Problem phenomenon
On an OSPF network, configured OSPF router IDs conflict sometimes. Once a router ID conflict occurs, OSPF LSAs are frequently aged and generated, causing network unstable. This is because a router ID uniquely identifies an OSPF device. When a router ID conflict occurs, the following situations occur:
The CPU usage is high, which is mainly caused by the ROUT task.
Routing flapping occurs.
Methods of determining an intra-area router ID conflict
The network topology is assumed as follows:
Figure 1 Networking diagram
SwitchA, SwitchB, SwitchC, and SwitchD in area 0 establish OSPF neighbor relationships. The router IDs of SwitchA and SwitchC are 10.1.1.1. Thus, a router ID conflict occurs.
Identification method:
Run the display ospf lsdb command on any of the devices every one second to check whether the Age field in the Router LSA frequently changes and whether the value of the Sequence field increases quickly.
<SwitchA> display ospf lsdb
OSPF Process 1 with Router ID 10.1.1.1
Link State Database
Area: 0.0.0.0
Type LinkState ID AdvRouter Age Len Sequence Metric
Router 10.4.4.4 10.4.4.4 1410 48 80000003 1562
Router 10.2.2.2 10.2.2.2 2 48 8000001C 1562
Router 10.1.1.1 10.1.1.1 6 36 800015D0 1562
Network 10.22.22.1 10.2.2.2 7 32 80000001 0
Network 10.11.11.2 10.2.2.2 23 32 80000002 0
Link State Database
Area: 0.0.0.0
Router 10.4.4.4 10.4.4.4 1411 48 80000003 1562
Router 10.2.2.2 10.2.2.2 3 48 8000001C 1562
Router 10.1.1.1 10.1.1.1 0 36 800015D3 1562
Network 10.22.22.1 10.2.2.2 8 32 80000001 0
Network 10.11.11.2 10.2.2.2 24 32 80000002 0
In this example, on the device with the router ID being 10.1.1.1, the Age field in the Router LSA frequently changes and the value of the Sequence field increases quickly.
Run the display ospf routing command on SwitchB every one second, and you can find that route flapping occurs. If intra-area route flapping occurs but neighbor flapping does not occur, it can be determined that a router ID conflict occurs.
<SwitchB> display ospf routing
OSPF Process 1 with Router ID 10.2.2.2
Routing Tables
Routing for Network
Destination Cost Type NextHop AdvRouter Area
10.33.33.0/24 3124 Transit 10.22.22.2 10.4.4.4 0.0.0.0
10.22.22.0/24 1562 Transit 10.22.22.1 10.2.2.2 0.0.0.0
10.11.11.0/24 1562 Transit 10.11.11.2 10.2.2.2 0.0.0.0
Total Nets: 3
Intra Area: 3 Inter Area: 0 ASE: 0 NSSA: 0
Routing Tables
Routing for Network
Total Nets: 2
Intra Area: 2 Inter Area: 0 ASE: 0 NSSA: 0
Methods of determining an inter-area router ID conflict
Figure 2 Networking diagram
The router ID of SwitchA (such as S6700-24-EI)conflicts with that of SwitchC, but SwitchA and SwitchC are not in the same area.
Run the display ospf lsdb command on any of the devices every one second. If a large number of AS external LSAs from the same device are frequently refreshed, it can be determined that an inter-area router ID conflict occurs.
<HUAWEI> display ospf lsdb
Link State Database
Area: 0.0.0.0
Router 10.2.2.2 10.2.2.2 172 48 80000002 1562
Router 10.1.1.1 10.1.1.1 174 48 80000003 1562
Sum-Net 10.22.22.0 10.2.2.2 166 28 80000001 1562
Sum-Asbr 10.1.1.1 10.2.2.2 38 28 80000001 1562
Link State Database
Area: 0.0.0.0
Router 10.2.2.2 10.2.2.2 173 48 80000002 1562
Router 10.1.1.1 10.1.1.1 175 48 80000003 1562
Sum-Net 10.22.22.0 10.2.2.2 167 28 80000001 1562
Sum-Asbr 10.1.1.1 10.2.2.2 39 28 80000001 1562
AS External Database
External 10.100.2.0 10.1.1.1 3600 36 80000004 1
External 10.100.3.0 10.1.1.1 3600 36 80000004 1
External 10.100.1.0 10.1.1.1 3600 36 80000004 1
Generally, a router ID conflict occurs on a network sometimes. Therefore, you need to master the methods of determining a router ID conflict to quickly locate the fault. After eliminating the router ID conflict, run the reset ospf process-id command to make the configuration take effect.
Cisco 3845
