2.6 install insues
2.6 install insues
Post by Guest » Tue Dec 14, 2010 8:06 pm
Hi,I have taken over an install and have come across some issues:CS and RME LMS2.2 were installed. When trying to install CM, the install tries to stop the dmgtd process but apparently fails. I then tried to install LMS 2.5 ontop of this but have thesame issues (see attached). If I try to manually kill these processes, a new process is created. How tdo I terminate them to continue the install?Cheers in advance!
Re:2.6 install insues
Post by Guest » Tue Dec 14, 2010 9:45 pm
You can simply kill these process with kill -9 (e.g. kill -9 1021).  The problem with dmgtd not being able to kill off all apps when LMS is installed into a custom NMSROOT is fixed in Common Services 3.0.6 which is part of LMS 2.6 SP1.
Post by Guest » Tue Dec 14, 2010 11:06 pm
Thanks for your help. I really appreciate it. I'm more IOS focused and not Solaris. The organisation I work with depict that the folder structure unfortunately. I followed your advise but unfortunately the processes start up again (see attached). I can't uninstall or do anything until I kill these. Any other tips perhaps?Cheers in advance
Post by Guest » Wed Dec 15, 2010 12:01 am
Daemon Manager must still be running.  Post the entire ps -efl output.
Post by Guest » Wed Dec 15, 2010 12:41 am
Yup,See attached. Seems to be stop or CW's thinks it is anyway.
