SDM Install Trouble
SDM Install Trouble
Postby Guest » Mon Jan 03, 2011 9:50 am
I am having difficulty installing SDM v2.5 on a 1841 router.  I have connectivity to the router, I have a login with privilege level 15.  I am able to telnet to and login to the router fine.  However, when I run the SDM setup, it gives the error message that SDM was unable to connect to the router.
I sniffed the network and SDM does telnet to the router, login, and then goes into and exits config mode, and that is it.
I do not have SSH enabled, but I'm not aware that that is necessary to install SDM.
Re:SDM Install Trouble
Postby Guest » Mon Jan 03, 2011 9:51 am
Any access-list and or access class configured on the router that may be preventing SDM access?
Postby Guest » Mon Jan 03, 2011 11:10 am
No, there are currently no access lists setup on the router at all.  Nor is any sort of firewalling turned on on the host computer I am trying to install from.
Postby Guest » Mon Jan 03, 2011 11:48 am
Try to move the files manually via TFTP to the router's flash. Full SDM requires following files:
sdm.tar
sdmconfig-modelnum.cfg
home.tar
home.shtml
common.tar
Hope it helps...
Postby Guest » Mon Jan 03, 2011 12:41 pm
All of the files were already in the flash of the router except the sdm.tar file.  I transferred this file, and now full SDM does appear to be running on the router.  Thanks for the help.
Users browsing this forum: No registered users and 5 guests
