Where I can find Full list of Cisco documentation
post links, tutorials, general network information and other useful information.
Postby Guest » Thu Apr 28, 2005 2:20 am
Could somebody give me the link or give answer for next question:
I want to know all list for documentation descriptions. Forexample
There are cisco documents:
Cisco Unified   Communications System Documentation
CUCE Software   & Hardware Compatibility Guide
Cisco comptatibility matrix
Cisco administration guide
etc.
Each of this document is very useful.
Now attention!
My question: Where I can find full list of guides with description where they could be useful for me.
Thank you a lot!
Re:Where I can find Full list of Cisco documentation
Postby Guest » Thu Apr 28, 2005 3:13 am
Go to this website:  http://www.cisco.com/en/US/products/sw/voicesw/index.html
From there, you can choose the product of your choice by clicking the Data Sheet link.
Hope this helps.
Postby Guest » Thu Apr 28, 2005 4:03 am
You can find all Cisco documentation in several ways:
From the Support home page http://www.cisco.com/cisco/web/support/index.html, take Option 1 and either enter a product name to search for, or select from a category list, or take Option 2 and start from the task you want to do (Install, etc).
Or – you can go right to the Product Selector Page http://www.cisco.com/cisco/web/psa/default.html?mode=prod&level0 where you start by selecting a product or technology category, then select a product line, then select a specific product. From the next page you’ll see a list of all docs for that product.
Or - from the main Cisco.com page, www.cisco.com - Choose QuickLinks (at the lower right) and from the menu choose Documentation.
Here’s a tip if you are looking for system documentation: Although there is no category for system documentation, if you type “system” in the find box on the main Support page or the “Select Your Product” page, you’ll get a list of all products with “system” in their title.
This works with any other term you want to find in a title.
Alternatively, you can get to some system docs through the selector tree. For example, for Cisco Unified Communications System, choose Voice and Unified Communications > Unified Communications Systems > Cisco Unified Communications System.
Please let us know if this helps you find what you are looking for, and thanks for your query,
Hilde
PS If you want to know a bunch of tips and tricks for finding information on Cisco.com, we recommend this short feature tour http://www.cisco.com/web/tsweb/flash/support/ngw/cisco_support_tours.html.
Postby Guest » Thu Apr 28, 2005 4:52 am
Thanks for the rating.
Return to Resources for Network Administrators
